1998 Dodge Caravan Door ajar light & interior lights go
114,895 MILES • 6 CYL • AWD • AUTOMATIC
ITALIANLADY1984
I just purchased a 1998 dodge caravan and it passed safety & admissions. But when you are driving and hit a bump the door ajar light goes on and so do the interior lights they fllash off and on and recently in addition to that it occurs when you put your foot on the break or gas petal . What is this from any help would be appreciated Thank you
Feb 21, 2010 at 10:56 AM
BMRFIXIT
  • 19,053 POSTS
Check side doors pins
Spray penetrating oil in door latches and rear door too
Feb 21, 2010 at 11:05 AM
ITALIANLADY1984
I tryed this but it didnt work I took out the sliding door pins but it still dings & the door ajar light flashs & the locks are still going on and off
Feb 22, 2010 at 9:59 AM
BMRFIXIT
  • 19,053 POSTS
Next step is to hook it up to a scanner as that should show the faulty switch
Feb 22, 2010 at 1:28 PM
ITALIANLADY1984
so would you recommend sending it to a mechanic that specials in electrical repairs?
Feb 26, 2010 at 7:08 AM
BMRFIXIT
  • 19,053 POSTS
Next step is to use a scanner
As that should pin point the troubled area
you can ask to have it checked some may charge about $50 for the scanner test
good luck
Feb 26, 2010 at 10:09 PM
