1997 Dodge Caravan wont start and the coil is good
MOAPAR4081
  • 1997 DODGE CARAVAN
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
hello ! My friend was driving this van and it just shut off and it wont start back up now. It was low on oil so we filled it back up and I un hooked the battery and thought maybe it would reset itself and start but no luck. Could it be the crank sensor
Saturday, August 23rd, 2008 AT 2:57 PM
To determine if its fuel or spark problem do below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
Saturday, August 23rd, 2008 AT 4:01 PM
