1997 Dodge Caravan Won't Start
P.ECHIRIBEL
  • 1997 DODGE CARAVAN
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
The motor cranks all the lights work but won't start. It has fluid, oil and gas. I pulled up to a stop light and it stopped running now it won't start. Please Help.
Tuesday, December 23rd, 2008 AT 5:19 PM
Do below to determine if its fuel or spark issue-then tell me what happend
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, December 23rd, 2008 AT 6:00 PM
