1997 Dodge Caravan won't start
WELDDOC
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 197,000 MILES
This is a strange problem. Occasionally, When I start this van I get no fuel gauge reading, no shift indcator, no odometer reading and no temp gauge reading. The engine will start but only run for 2-3 seconds and die. This may happen for a short time or may last 2 or 3 days but will always start sfter waiting awhile. I have cleaned battery cabbles, put on new ends, cleaned all the grounds I can find. I have replaced battery just becuase. Took lower dash apart looking for bad connections but I can't find any. I got desperate and took it to a dodge dealer and they found the same thing it starts after a couple of days. But when it won't start it always has the same simptoms, no dash and runs for 2-3 seconds. I'm stumped
Monday, May 26th, 2008 AT 10:22 PM
LEGITIMATE007
  • 5,121 POSTS
Have your alternator checked. And spark and fuel
Monday, May 26th, 2008 AT 10:50 PM
LEGITIMATE007
  • 5,121 POSTS
You can check your spark here:
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Monday, May 26th, 2008 AT 10:54 PM
LEGITIMATE007
  • 5,121 POSTS
Check your fuel pressure here:
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Monday, May 26th, 2008 AT 10:55 PM
