1997 Dodge Caravan Ignition Control Module
1997 DODGE CARAVAN
PITCREW94
  • 18 POSTS
Engine Performance problem
1997 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Does anyone know where the 1997 Dodge Caravan Ignition Control Model is located? What's the code for the Igniton control Module
Sep 25, 2010 at 2:06 PM
  • 110,244 POSTS
The ignition control module is now an integral part of the PCM. Do you have any codes?
Sep 25, 2010 at 4:18 PM
PITCREW94
  • 18 POSTS
[quote:33b1ea30d3="Jacobandnickolas"]The ignition control module is now an integral part of the PCM. Do you have any codes?[/quote:33b1ea30d3]
Hi Jacobandnickolas,
Thanks for the help. The code is P1391 ( Crank & Cam Sensor). The Van start right up.. Idle very smooth. When you come to a complet stop, the engine will shake like missing fire, Some time it will stall, but you can start right up. when you step on the gas pedal, it don't want to go untill acouple of second, Like a slip Transmission. Once the van is moving it drive fine. Is this Common on a 1997 Dodge Caravan with a 3.3 Motor? Please help if you can... Thanks...
Sep 26, 2010 at 3:11 AM
  • 110,244 POSTS
Have you had the sensors checked or replaced? Also, when you say it feels like the trans is slipping, does the engine rev and then engage? Finally, have you checked the fuel pump pressure?
Sep 27, 2010 at 3:26 AM
PITCREW94
  • 18 POSTS
[quote:bb912979b3="Jacobandnickolas"]Have you had the sensors checked or replaced? Also, when you say it feels like the trans is slipping, does the engine rev and then engage? Finally, have you checked the fuel pump pressure?
Joe[/quote:bb912979b3]
Hi Joe,
Yes I've replaced both sensor. and still do the same thing. But if either sensor fail, I thought it won't fire up. Is this correct? I also checked the fuel pressure, It's good. Yes.. The engine rev. and then engage. I thought it's the transmission but I man. shift it and its ok. Is this a common problem with this van?
Thanks,
Simon
Sep 27, 2010 at 5:22 AM
