1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
i have a 97 dodge caravan 3.3 I have fuel pressure, cranks over swapped relays around new cam and crank sensor, new pcm, new coil pac, the van will sometimes spark once then only crank at the same time the injectors get one pulse then only cranks, I have also checked for a shorted injector and didnt find anything wrong, ignition switch works properly, not sure where else to go.
SPONSORED LINKS
Wednesday, August 26th, 2009 AT 9:48 AM
