HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Not Running
1997 Dodge Caravan car wont start, makes ticking sounds whe
CACOLEMAN
MEMBER
1997 DODGE CARAVAN
6 CYL
2WD
AUTOMATIC
93,000 MILES
Where is the starter motor and selenold located.
Saturday, April 11th, 2009 AT 10:55 AM
JDL
MECHANIC
Hello, the starter should be located front side of engine, down low. One of the positive battery cables should go to the starter solenoid.
Usually a clicking sounds when trying to start is due to low voltage. Check the battery and cables.
SPONSORED LINKS
Saturday, April 11th, 2009 AT 11:07 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Dodge Caravan Will Not Start When It's Cold
I Bought The Caravan Last Feb. And I Live In The Desert. I Haven't Had Any Problems With This Van Since I Got It. It's Been An Outstanding...
Asked by
michael hubbard
1997
DODGE CARAVAN
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Dodge Caravan Car Won't Start After Disengaging...
Engine Mechanical Problem 1997 Dodge Caravan 6 Cyl Front Wheel Drive Automatic 100k Miles I Must Have Kicked The Security Chip (which...
Asked by
odonlin
1997
DODGE CARAVAN
Cranks Over But Will Not Start
My Van Is The Base Model. This Happened After A Hard Freeze. It Ran Perfectly Prior To That. I Allowed The Temperature To Go Above Freezing...
Asked by
Davisranch2017
1997
DODGE CARAVAN
My Water Pump Went Bad So Got A New Pump And Replace It And Belt It Will Statr For A Few Mins And Stop. 1997 Dodge Caravan Will Not Start...
Asked by
kp2446
1997
DODGE CARAVAN
Car Won't Start Unless Abnormal Pressure/torque...
1997 Dodge Grand Caravan, 3.3l Se: We Noticed Recently That When You Turn The Key To Start, Console Lights Come On, But It Does Not ...
Asked by
jpoliver
1 IMAGE
1997
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
