1997 Dodge Caravan ALTERNATOR
16,300 MILES • 6 CYL • FWD • AUTOMATIC
RAIN14
i have 97 dodge carvan , and my battery light came on so i check to see if my alternator was working so i took one cable off the battery to see if it will stay running so when i did this it cut off i took off the alternator off to get it check out at auto zone and it check out good i put it back on charge the battery back up, put the alternator back on drove the van for a little while and it cut off again so then i change the belt, put everything back together charge the battery back up,test the battery and it good. drove it around again and it cut off again while i was driving so what else come be wrong because i have had the alternator check twice once at auto zone and once at krangen and both time it was good so were do i go from here.
Dec 29, 2008 at 8:00 AM
ZACKMAN
  • 4,202 POSTS
Instead of removing the alternator out of the vehicle, go back to Kragen with the vehicle, and have them test the alternator in the car. If their hand held tester said too low or too high voltage output, the problem lies in your PCM. Your alternator output is controlled by the computer, so if there is anything wrong, it is your computer.
Dec 29, 2008 at 3:00 PM
RAIN14
i was told the same thing, i was also told if it is my computer then i would have to get a whole new box and then have it program to my engine is that right. or is there another way where it will not cost me so much
Dec 29, 2008 at 5:49 PM
ZACKMAN
  • 4,202 POSTS
Unfortunately, your option is limited. Your "new" computer will have to be reprogrammed so it will work with the vehicle.
Jan 1, 2009 at 9:12 AM
RAIN14
i would like to thank you for the information. it was my alternator all along, so everything is alright now
Jan 1, 2009 at 5:01 PM
ZACKMAN
  • 4,202 POSTS
I am glad everything worked out well for you.
Jan 2, 2009 at 10:47 AM
JUNIOR14
How did you come to the conclusion to replace the alternator even when it passed and not the PCM
Jan 28, 2009 at 3:42 PM
