1997 Dodge Caravan
JEFF_CHARMCGARD
  • 1997 DODGE CARAVAN
Engine Performance problem
1997 Dodge Caravan
Why doesn't the van start. Seems like not getting gas?
cranks and turns when boosted
Friday, October 2nd, 2009 AT 7:01 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Jeff,
What you will need to do it check and make sure the is fire (spark) to the plugs. To check have a philips screw drive handy, pull a plug wire off of a plug stick the crew driver in were the plug would go and hold it about a 1/2" away from a good ground and have someone try to start the vehicle. If there is spark it should be a Bright Bluish/White.
If spark checks good then will need to check fuel pressure. Check link below for video on checking fuel pressure...
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Friday, October 2nd, 2009 AT 7:16 PM
