TCC code--what to do?
1996 DODGE CARAVAN
219,000 MILES • 6 CYL • 2WD • AUTOMATIC
WAR1968
I bought the van used and it had already had it's tranny replaced once (at 150,000). I have a TCC code and from the sounds of some of the questions in you site, I need to check everything out before I just let someone change the trans out again. The van runs fine when not at operating temp but once it gets there the trans lurches like going into passing gear, begins a high pitch whine, rpms are up (I don't have a tach) and it won't shift out of second. Nothing stops it except parking and allowing it to cool. What else should I look at before condeming the trans.
Oct 8, 2008 at 10:25 AM
MERLIN2021
  • 17,250 POSTS
The transmission needed to be reset, you can do this by cycling the ignition switch 6 times. This is a common problem.
Oct 8, 2008 at 4:02 PM
WAR1968
Thanks for the help, that worked perfectly! :-) Great site!
Oct 9, 2008 at 1:59 PM
