1994 Dodge Caravan
ARTG5
1994 Dodge Caravan
I need to change the oil pan gaskets. How hard is it and what does it entail? Does the engine have to come 1/2 out like older model cars? Are there torque specs for the bolts and a torque pattern? Any help would be appreciated. Thanks.
Sep 14, 2009 at 3:09 PM
CARADIODOC
  • 34,415 POSTS
It's mostly Fords that need the engine raised to remove the oil pan. Yours might require removal of the front engine mount and starter, but that's about all.
Oil pan bolts are torqued to:
2.5L: 105 inch pounds
3.0 L: 50 inch pounds
3.3L: 105 inch pounds
If you don't have an inch pound torque wrench, use common sense; these are small bolts, and the 3.0L engine block is aluminum. The only gasket you'll find is in the aftermarket world. Chrysler and their techs use gasket sealer, no gaskets. I like the Mopar gray stuff myself because it will seal even if there is a film of oil on the pan or block surface. If you use the Mopar black RTV sealer, both surfaces MUST be dry and free of any oil residue or it won't seal in that spot and it will leak. The black stuff stays more rubbery and is easy to clean off next time. The gray gets harder and will need a wire wheel to clean it all off next time.
caradiodoc
Sep 14, 2009 at 3:46 PM
ARTG5
Thanks, but you dont happen to know the torque pattern do you? I'm doing this for a guy, and I asked him to get a Haynes manual, but don't know if he has yet (or will). Of course I guess if he doesnt he doesnt really want it done either. Any info will help though. Thanks
Sep 15, 2009 at 4:18 AM
CARADIODOC
  • 34,415 POSTS
There's no particular torque sequence because this is just a stamped steel pan and is very flexible. Special tightening order is only necessary with rigid parts that must not be clamped unevenly to prevent warping, such as cylinder heads.
Most experienced professionals wouldn't even bother with the torque wrench on items such as this. Hand tightening with a 1/4" drive ratchet and one hand is plenty tight assuming you're using gasket sealer, not an aftermarket cork or fiber gasket.
caradiodoc
Sep 15, 2009 at 5:31 AM
ARTG5
Thanks, you've been very helpful. I havent done an oil pan in years, can't even remember what it was on. One last question, do you know the torque spec for the forward engine mount I'll (maybe) have to remove?
Sep 15, 2009 at 3:15 PM
CARADIODOC
  • 34,415 POSTS
There's so many numbers given depending on which bolts you remove and which engine you have. Use common sense. And, pay attention to how hard you have to tug on the wrench to get them loose.
Besides torquing the bolts, you must consider that rust in the threads will affect the clamping forces. In the name of speed, most mechanics run the bolts in with an impact wrench and don't worry about torque specs.
caradiodoc
Sep 15, 2009 at 3:52 PM
ARTG5
I think I have all the info I need now, thanks again for all your help.
Sep 16, 2009 at 4:24 AM
