2000 Dodge Caravan Loosing oil by the gallon....
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROWDS99
It looks like the oil pan gasket has given out right where the bottom pully goes into it.
Nov 17, 2008 at 10:55 AM
  • 31,937 POSTS
HI there,
I feel that it will actually be the front crankshaft seal and the pulley, wash it down and inspect after a short drive, if there is oil flung around the back off the pulley that will be your problem i feel.
mark (mhpautos)
Nov 17, 2008 at 7:42 PM
ROWDS99
That's precicely what I discovered... Just how hard, and how long will it take for a do it yourself?
Nov 18, 2008 at 2:30 AM
  • 31,937 POSTS
Hi there,
I will check this out and post details for you.
Mark (mhpautos)
Nov 18, 2008 at 7:31 AM
  • 31,937 POSTS
Hi there ,
The data base advises just the basics, it looks as if the harmonic balancer puller is just a standard version, time wise i would say a good 2 hrs for a home mechanic as long as the pulley comes off easily. replace the seal and the pulley as a set as the seal surface on the old pulley will be grooved.
mark (mhpautos)
Nov 18, 2008 at 6:24 PM
