Engine stalling?
GEMINILLP
Its the cam sensor. Us girls know alot more then guys give us credit for. I hope this helped you out.
Monday, September 21st, 2020 AT 6:57 PM (Merged)
SKIP1939
  • 1992 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 170,000 MILES
Engine shuts off but will restart after sitting 2 or 3 minutes
driving over bumppy road will cause the engine to shut off. Will restart after sitting 2 or 3 minutes
sometimes in a turn to the left engine will shut off. Will restart after sitting 2 or 3 minutes
went about a month without it shutting off. Now doing it again
seems like a coil getting hot. Cooling off
or
gas filter
someone suggested vapor lock
love these old vans but this one is getting me. Thanks, skip
JALOPYPAPA
  • 467 POSTS
I had similar symptoms and found brittle, nearly broken wiring at the the crankshaft position sensor; replaced the sensor and it runs fine. On the 3.3 liter engine, it's at the back left.
EDLOPEZ
  • 6 CYL
  • FWD
  • 212,000 MILES
My Dodge Caravan stalls after I put it in reverse and/or drive while I turn my the wheel. Engine idle starts to go bad and it turns off. It will run good when it runs in a straight line, but as I slow down to make a turn it stalls. I also got a 41 code which is for the alternator field is not switching properly. Any suggestions will be gratefully taken. Thanks.
  • 109,779 POSTS
Hi:
It sounds like the alt may be going bad. As far as the engine, have you had the throttle position sensor checked? If it' bad, the car will run fine when you are giving it gas, but when you take your foot off the gas, it will have a bad idle and most times stall.
NEALRAYEZ
  • 3.0L
  • 6 CYL
  • FWD
  • 154,000 MILES
Speedometer erratic and engine stops momentarily. Speedometer goes to 100 then back to zero while driving. The engine shuts off for a second and then resumes.
It is quite disconcerting since I have a one hundred plus mile commute.
DOCFIXIT
  • 18,828 POSTS
Is the check engine light on? If yes go to parts store have code read then post will advise.
STEVE W.
  • 13,496 POSTS
Sounds like a short in the speed sensor wiring. Check on the passenger side of the engine and see if the wiring harness has chaffed through and is rubbing on the edge of the cylinder head.
