1992 Dodge Caravan misaligned timing marks and CAM degreein
NELSEC
  • 1992 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 102,000 MILES
I'm changing the head gaskets and in the process of removing the cam and crankshaft sprockets I lost TDC and moved the sprockets. Now I can't get the distributor pointing correctly or the timing marks alligned. They are all off! What should I do?
Thursday, November 13th, 2008 AT 11:35 PM
  • 109,885 POSTS
Hi:
You will need to remove the timing belt and reset the timing. If you need a guide, go to the "Popular Site Links" on this page. Select "Drive Belt Routing Diagrams." Put in the vehicle information and it will provide a diagram.
I hope this helps.
Saturday, November 15th, 2008 AT 12:16 AM
