1992 Dodge Caravan Engine wont start
RUFFYSANTI
  • 1992 DODGE CARAVAN
  • 4 CYL
  • FWD
  • 150,000 MILES
I stored the van a few months back and it was running. I pulled it out of storage and I cant start it. Tried starting fluid and it will run for around 10 seconds and stop filled up the carb with gas and will run for a few more seconds tried to disconnect fuel line to carb to see if it spits out fuel while I crank the engine. It wont what should I do
Monday, April 28th, 2008 AT 11:31 PM
LEGITIMATE007
  • 5,121 POSTS
Do you hear the fuel pump turn on when you turn the key on? I have a check you can do for fuel pressure. Your regulator is probably shot.
Monday, April 28th, 2008 AT 11:49 PM
LEGITIMATE007
  • 5,121 POSTS
Go here to check fuel pressure
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Monday, April 28th, 2008 AT 11:50 PM
