1992 Dodge Caravan I can run Grand Caravan start no problem
DEMONSHATTER
  • 1992 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 200,000 MILES
I can start my grand caravan run with no problem then next time she turn over but wont start.(I ready replace plugs and coil )what else should I look for?
Friday, March 26th, 2010 AT 6:49 AM
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Do below to determine whether it's fuel or spark issue:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, March 26th, 2010 AT 7:06 AM
