1985 Dodge Caravan Crank shaft
BRIANHERBERT
  • 8 POSTS
Electrical problem
1985 Dodge Caravan 4 cyl Two Wheel Drive Automatic
Is it possible to check the crank shaft of a 1985 Dodge Caravan? I am having electrical problems and the last response I got on here suggested to check the crank shaft. Engine rotates, but wont start. Battery is good, but no spark coming out of coil wire at distributor cap. Coil has been replaced. Please help.
Aug 3, 2010 at 9:49 AM
CARADIODOC
  • 34,417 POSTS
Hi brianherbert. Welcome to the forum. I think they meant the "crankshaft position sensor". That's the flat round disc under the rotor in the distributor. It's also called the "Hall Effect Switch" and is a common failure item.
While the distributor cap is off, also check that the rotor is turning when you crank the engine. If it does not, suspect a broken timing belt.
caradiodoc
Aug 4, 2010 at 7:44 AM
BRIANHERBERT
  • 8 POSTS
the "crankshaft position sensor" is turning because the rotor is also turning.
Do you have any idea why there could be no spark coming from coil?
Aug 4, 2010 at 10:27 AM
CARADIODOC
  • 34,417 POSTS
Just because the distributor shaft is turning doesn't mean the sensor is good. Check for voltage on the primary coil wire. I can't remember about an '85 model, but on the newer models there should be 12 volts on the feed wire for one second after turning on the ignition switch, then again during engine rotation, (cranking or running). If your engine uses a carburetor, you might find voltage to the ignition coil all the time the switch is on.
That Hall Effect Switch in the distributor is what tells the Engine Computer when to fire the coil. It has a magnetically-switched transistor circuit. The reluctor is a set of metal vanes that interrupts the magnetic field and induces the pulse in the assembly. Those sensors are such high failure items, a lot of people carry spares in the glove box.
caradiodoc
Aug 4, 2010 at 11:05 AM
BRIANHERBERT
  • 8 POSTS
Hall Effect Swith was replaced today, still no spark at coil lead. I also replaced coil lead and coil.
Aug 5, 2010 at 10:36 PM
CARADIODOC
  • 34,417 POSTS
Did you check for voltage on the coil primary wire?
caradiodoc
Aug 7, 2010 at 1:24 AM
BRIANHERBERT
  • 8 POSTS
Yes, there is voltage on both terminals. 12 volt positive, 6 volt negative.
Aug 7, 2010 at 5:35 AM
CARADIODOC
  • 34,417 POSTS
Sorry for the delay. I'm trying to put my hands on an '85 service manual. 6 volts on the coil's ground wire doesn't sound right. The positive wire should have full battery voltage, either whenever the ignition switch is turned to run, or just during cranking, depending on the model year. The negative coil wire should have near 0 volts except when it fires; then it should go to 12 volts for just an instant.
With my fading memory, I would have to blame the Engine Computer but I'd sure like to look at the diagram in the manual first.
caradiodoc
Aug 10, 2010 at 6:41 AM
