1997 Dodge Caravan crankshaft seal
1997 DODGE CARAVAN
GEARHEAD611
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
how do i change the front crankshaft seal?
Dec 8, 2008 at 12:48 PM
ZACKMAN
  • 4,202 POSTS
Raise vehicle
Remove passenger side wheel
Remove passenger side splash shield
Remove drive belt
Remove dampener bolt and remove dampener (harmonic balancer)
Use seal removal tool C-4991 (available for rent from most auto parts store - if you don't want to purchase one) to remove the seal from timing cover.
Use seal installer tool C-4992 with the seal's spring side towards the engine, install until surfaces are even
Install harmonic balancer. Torque to 40 ft/lbs
The rest is reverse of removal
Dec 9, 2008 at 10:40 PM
