Does not start, fuel injection problem?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,255 POSTS
Nope, you do not have to code the fuel injectors to the ECM.
Tuesday, May 14th, 2024 AT 9:38 AM
ABAYA
  • 77 POSTS
Thank you sir,
But the ecm throw the dtc P268A. Is this have a relation with injectors programming?
Tuesday, May 14th, 2024 AT 9:48 AM
KEN L
  • 54,255 POSTS
P268a “fuel injection calibration not learned/programmed”
The ECM might need to go through a relearn procedure to properly calibrate the fuel injectors. This can often be done with a professional scan tool. Here’s a general outline:
Step 1: Turn the ignition to the "ON" position (engine off) for about 10 seconds.
Step 2: Turn the ignition to the "OFF" position for about 10 seconds.
Step 3: Repeat steps 1 and 2 a couple of times.
Step 4: Start the engine and let it idle for a few minutes.
Step 5: Perform a test drive to see if the code returns.
Please let me know.
Tuesday, May 14th, 2024 AT 10:17 AM
ABAYA
  • 77 POSTS
I applied the procedure you indicated, but the engine did not start. Maybe I have to use the scanner to reprogram injectors. Thank you very much. Thank you sir,
I'll try this tomorrow.
Tuesday, May 14th, 2024 AT 11:24 AM
