Engine stalls at idle
UGSTEVE
  • 1991 CHEVROLET TRUCK
Electrical problem
1991 Chevy Truck 4.3 litre engine Two Wheel Drive Automatic 140000 miles
I replaced all the sensors on the throtle body, new wires, spark plugs, cap and rotor and it ran fine but now it just misfires and will will not idle properly. If I get it started when it is cold. Its a miracle to keep it running.I checked the spark theres pletty there. Pletty of fuel going to the throttle body injection. Is there a pickup coil on these that could cause the problem?
Wednesday, November 25th, 2020 AT 8:17 AM (Merged)
BLACKOP555
  • 10,371 POSTS
So you already replaced the IAC?
Replace your Coolant temp sensor *ECT* also a bit of a note is throttle body injected TBI, are known for hard cold starting, when the fuel hits the cold plate it doesnt evaporate effectivley, but when it warms up it gets better because the plate warms up and the fuel evaporates move efficently, thats why most intake manifolds have coolant passages in them so the fuel vaporizes more efficently and doesnt condensate into liquid, because liquid gas doesnt burn.
RAULETTA
  • 1994 CHEVROLET TRUCK
Engine Mechanical problem
1994 Chevy Truck Two Wheel Drive Automatic
OK. HOPE U HAVE SOME TIME. (Sorry for cap lock). I have a 1994 chevt truck frame National RV w/ a 454. (Chassis and engine are actually 1993). I purchased it for $2500.00. Apparently it was purchased used in 2006 and ran great for a couple of years. Then the problems began. When the enging is started it stalls, and won't idle. If I disconnect the temp sensor then it idol's fine. Under a load it doesnt run well. No error codes come up (unless I disconnest the temp sensor). On diagnostice "lean condition" came up
stuff changed:MAP, Throttlebody injectors, plugs, cap, rotor, wirers, pcv, computer
stuff checked : compression fine, stalls right out when TBI intake blocked, vacuum, fuel, fuel pressure.I reconditioned the egr which was stuck.
Wednesday, November 25th, 2020 AT 8:18 AM (Merged)
DR LOOT
  • 2,311 POSTS
If I had to place a bet on it I would say the EGR
RAULETTA
Thanks for the reply. I can look into that next. I am in the process of removing the catilytic converter. To bypass this and chech if perhaps it's plugged. I doubt it but 3 seperate mechanics have suggested I do this.
Bummer- the engine pipe is not only clamped but welded to the cat.
DR LOOT
  • 2,311 POSTS
Before you go through all that work, tell me if you can hold your hand over the exhaust and plug it, is it very easy, and how long you can hold your hand on their before you lose it, make sure you wear a glove if the truck is hot.
VETTESLAVE
  • V8
  • 4WD
  • 103,000 MILES
Engine Starts great. Runs good at highway speeds. When it reaches normal operating temp. And you stop in gear it stalls out. Then starts up with no problem.
I have replaced the plugs, wires, cap, rotor, fuel filter.
  • 109,885 POSTS
Has the check engine light come on? Have you checked for vacuum leaks or EGR problems?
EDWARD REED
Two overlooked items that wound up fixing the vacuum problems causing my vehicle to stall whenever in gear and my foot not on the accelerator: EGR boot and oil filler cap.
The EGR valve boot had 2 issues: 1) the flange on the valve was not seated in the recess of the boot. Once seated properly, the stalling condition became intermittent instead of constant. When I replaced the boot, stalling became rare.
That's when I knew I was onto something. Having gone through every suggestion seen in this post, including checking and replacing everything I assumed was vacuum related, I was overlooking the operational aspect of how that "port" vacuum is created. Most of the vacuum used in an engine comes from the intake side cam housing. Any leak there cannot be overcome at idle when in gear. When you're depressing the accelerator, you often generate vacuum to spare.
With my oil filler cap so easy to remove and put back on I decided to try changing that. If it's a breeze to remove the cap, it isn't sealing.
Stalking became a thing of the past on that vehicle for months. Suddenly the symptoms reappeared in full force. I went back through all of the vacuum system and found that the oil cap, the one I just replaced, was like jelly. The rubber was softening at operating temperature. I replaced the filler cap again. Same part, same brand (Help!), And that was years ago. They must have had a bad batch of rubber with the first cap I bought.
Debug was simple on the EGR and filler cap. With the engine running and warmed up, assisted by someone holding their foot on the brake and putting the vehicle in gear, the idle can be made happy by just pushing the valve or cap down. On the EGR that was true whether it was the valve flange not seated properly in the boot, and in determining the entire boot had gone past its serviceable period.
On my daughter's car, the intake camshaft housing gaskets were leaking. Oil was seeping out, so air (and dirt) was getting in. The air getting in was causing vacuum pressure to drop enough that her car intermittently stalled in gear when warmed up, with the foot off the accelerator. The constant symptom was a grumbling engine. It just sounded like it didn't want to be bothered.
Vacuum leaks entail more than just vacuum lines and fittings.
Rubber does the opposite of almost every other material when temperature variations occur it shrinks when hot and expands when cold. This is why the symbiotic relationship between rubber and metal creates such a great seal.
One more stalling issue under the same operating conditions came about on my Chevy. The seal on the vacuum dump tube to the exhaust cam cover, another rubber boot similar to the EGR valve boot (including the flange seat) was old and tired too. I could not find a replacement. The inner diameter was smaller than the EGR boot, but otherwise identical. To fix the exhaust vacuum leak I had to resort to adding a layer of heat shrink tubing to the vacuum dump tube and two layers of heat shrink tubing to the outer surface of the boot. I don't like it, but it works. How that dump tube works I imagine is to maintain vacuum when none of the intake valves are open.
None of those issues were what I expected to include when inspecting for vacuum leaks. Add them to your checklist and you might save yourself a lot of time, money, aggravation and the failures that come with trial and error.
Thursday, May 26th, 2022 AT 8:13 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Friday, May 27th, 2022 AT 5:16 PM
