1965 Chevy Truck
1965 CHEVROLET TRUCK
88,000 MILES • V8 • 2WD • MANUAL
MCARDLEP
Truck starts and immediately shuts off. Any ideas?
Sep 8, 2009 at 3:25 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
This a stock 65? what engine? points ignition?
Sep 8, 2009 at 3:34 PM
Turn key On check for battery voltage on the coil positive terminal do you have it-if not the ignition circuit is open or you have a defective ignition switch-
Or do this get a jumper wire connect one end to the coil positive terminal and the other to the battery positive post-did it continue to run if so check and test above-
Sep 8, 2009 at 3:37 PM
