Dash board lights?
RHALL77
  • 3,361 POSTS
Have the bcm scanned to make sure there are no codes in it
Friday, August 23rd, 2019 AT 4:22 PM (Merged)
DAVID LYNCH
  • 2002 CHEVROLET IMPALA
  • 3.8L
  • V6
  • 190,000 MILES
My. Tail lights are out and so are my dash lights. My radio said locked but turned back on.Y security on my little screen on my dash blinks. We changed the ignition alost a year ago. I had to take it to a shop for them for bypass an after market alarm system and remote start that the previous owner did n I wasn't aware of. I have owned the car for 3 years and that way the only problem till now
DAVID LYNCH
It's a 2002 chevy impala 3.8l sorry I didn't put that
HMAC300
  • 48,601 POSTS
You need to reset security or have it scanned to see what is wrong with security system. The radio unlock will be in your owner's manual if you have one if not look online. Have a local pro scan for codes to see if there is a body module problem for the lights and check fuses under hood as well and in car
CHIEFALIZE
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • 131,000 MILES
Why do my air bag light come on while i'm driving.
DENNYP
  • 1,824 POSTS
You have a fault with the air bag system and should have it checked out A.S.A.P. It could be something as simple as a loose connector.
LAVERNED
  • 6 CYL
  • FWD
  • 90 MILES
2001 Impala dash lights & radio lights black out. They work sometimes, mostly in the daytime. I tried shining a flashlight @ what I think is the daylight sensor (in the driver w/s defroster). I also need to know if I can only gain access to the switch by removing the dash? Thanks. E-mail mr_mac43@msn. Com with dashlights in the subject line.
ST.TIERNEY
I am very interested in this as well! I have a 2001 impala with the same issues! Tried new headlight switch! No fuses are blown! Now the tail lights are out! Getting very frustrated! Any help would be very very much appreciated!
GWATSON0008
  • 6 CYL
  • FWD
  • 150,000 MILES
I have a 2001 Impala, about 3 months ago all of the dash light except the odometer and gear section lighting went out, this includes my sterring wheel radio controls as well as all the lighting on my radio and AC/heat section, during dusk the radio and odometer area will light up but not for long and gauges are still out. Interior lamps all work. Fuses have been checked and are fine. Does anybody have an idea as to what causes this?
RENAUDTN
  • 636 POSTS
My wife's 2003 has a very similar problem.
Chances are you either have a bad headlight switch, or a problem with your BCM.
Take your headlight switch out (unplug it), then put a jumper between the brown/white wire and the grey wire; your instrument panel lights should come on. If they do, replace your switch, if they don't you likely have a problem with your bcm (it's also possible that the lights themselves went bad).
SHAY1988
  • 6 CYL
  • FWD
  • 68,000 MILES
How do I get the tire pressure low light to go off. I inflated all tire to correct pressure but the light will not go off.
METALGOD27
You have to reset the pressure monitor. Press the "DISP" button on your radio & hold it until you hear a beep from your speakers. Cycle through the settings until you see the tire monitor. Reset it there & your light should go off.
If you can't get this to work, turn the key to ACC, depress the gas peddle 3 times. Should hear a beep. That resets the tire monitor too.
TRUAX12
  • 6 CYL
  • FWD
  • 93,000 MILES
My dash board lights do not work all the fuses check out ok, can not read any gauges at night, can you help me
RHALL77
  • 3,361 POSTS
Try turning your dimmer switch back and forth, it may be a bad headlight switch. See if they will flicker when you do this
