2000 Daewoo Nubira what to check next
BAZZER
  • 2000 DAEWOO NUBIRA
  • 4 CYL
  • FWD
  • 93,000 MILES
Just got 2000 nubira engine quit last week just found out it was the timing belt broke was only doing about 25mph, replaiced the belt etc but only have compression in three cylinders what do I do next is it the valves and how do I fix it havent got any money at moment any help would be good thanks
Sunday, December 6th, 2009 AT 11:10 AM
DAVE H
  • 13,384 POSTS
You need to remove the head and replace the bent valves !
Sunday, April 11th, 2010 AT 7:04 AM
BAZZER
Hi dave, have replaced the valves new timing elt etc car runs but sometimes has a rough idle and then it wont excelerate smoothly you have to push pedal very gently and sometimes when you slow down it stalls it as if it gets bogged down and needs to clear before you push pedal again
thanks for any advice barry
Sunday, May 2nd, 2010 AT 2:08 PM
