2000 Daewoo Leganza No Spark
JUDE25
  • 2000 DAEWOO LEGANZA
  • 4 CYL
  • FWD
  • 147,000 MILES
Blew a head gasket. Changed it. All back together and it wont start. I am not getting any spark a #1.
I have worked and built American cars all my life. This is my first and last attempt at on a Daewoo.
Saturday, July 24th, 2010 AT 10:30 PM
KHLOW2008
  • 41,814 POSTS
Hi JUDE25,
Did you check the crank position sensor?
Sunday, July 25th, 2010 AT 4:14 AM
JUDE25
No I didn't check the crank position sensor. I didn't know it has one. Where can I find it?
Thank you for geting back to me.
Be Blessed
Sunday, July 25th, 2010 AT 10:29 AM
KHLOW2008
  • 41,814 POSTS
Crank position sensor is mounted to oil pump near a slotted wheel that is part of the crank pulley.
The A/C compressor bracket has to be removed for accessing it.
The other item to check would be the cam position sensor located near the cam pullies.
Sunday, July 25th, 2010 AT 2:29 PM
JUDE25
I decided to check the other plug wires. I am gfetting spark on 2 and 3, but not 1 and 4. I think that it may be a bad coil array.
I will look into the other items you pointed out also. I think that the sensor is Ok since it is firing on 2 and 3.
Thanks again.
Sunday, July 25th, 2010 AT 2:57 PM
KHLOW2008
  • 41,814 POSTS
If 2 and 3 is firing, then it is possible the coil is bad.
Good luck.
Sunday, July 25th, 2010 AT 3:09 PM
JUDE25
I concour with your answer. Now I just have to find a coil that won't break me.
Thank you again for [img]
Sunday, July 25th, 2010 AT 4:00 PM
