Electrical problem
2000 Daewoo Leganza 4 cyl Two Wheel Drive Automatic
Does "check engine" (MIL) dash light bulb comes on at ignition or briefly after start up.
I changed timing belt and had head rebuilt.
Assembled and now NO Spark and no MIL light at ignition turn on.
Replace ECM 2x, COIL pack and still no spark.
ECM ground ok,ECM fuse good,12v feed wires good to ecm. traced wires to ECM all good.
BUT NO MIL LIGHT at ignition.
OBD scanner shows all is ok or ? no bad codes.
Manual says if feed wires are good and ground is good and you don't have MIL light on at ignition then ECM is bad. Tried replacing...
Does check engine light come on before or after start of car to test bulb.
If Cam/crank sensor is a problem, still wouldn't the MIL light come on when key turned. I have spark tester. Thanks for any tips...Ken
Oct 24, 2008 at 6:28 PM
