Cranks will not start
132,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
EARL WALKER
I have the truck listed above 1500 with a hemi. It shut off at a red light one day and i assumed it was out of fuel since the gas station is where i was headed. well, I got it to start back up but had to keep the accelerator pressed. drove right across the street to the gas station; it spitted and sputtered all the way.. I put fuel in and would not start. Pushed it out of the way. Upon inspection found that there was no coolant in the reservoir or radiator. I out 1 gallon of 50/50 and 3 gallons of water in it. let it sit for bit. still wouldn't start unless holding accelerator to the floor. Had it towed to my house.. pulled and checked all injectors, replaced spark plugs and wires and still have the same issue. everything I have read so far suggests busted head gasket but oil looks fine and no signs of any leaks underneath the vehicle and no smoke ever came out of the tailpipe. so I want to look at other possibilities before pulling the heads and changing the gaskets.
Jan 4, 2021 at 5:03 AM
I think you are correct. It does sound like a head gasket. However, you don't have to pull the heads to confirm this.
Here is a guide that will solve this:
The next thing we need to do is run a compression test.
So let's start with this and go from there. However, if these check out then we need to start running through this guide on why an engine will not start.
https://youtu.be/dCjmRL3p4Cs
There is a lot of information here so let me know what questions you have.
Jan 5, 2021 at 10:17 AM
EARL WALKER
Apologies for delays responding. I appreciate your response. I have not had time to get out and try these yet but hope to soon. I will follow up. Thanks again.
Feb 22, 2021 at 12:22 AM
No problem. We are hear whenever you get back to it. Thanks for the update. We will wait to hear back. Thanks
Feb 23, 2021 at 10:23 AM
