the engine cranks but will not start and run why can you help me?
240,730 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MESABRINA
It bogs down sputters then backfire and stalls. I have replaced air intake hose bit, still have problems. Fuel pump just replaced still wont start?
Jan 17, 2018 at 9:03 AM
Good evening.
This sounds like the ignition module or fuel pump relay has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Jan 17, 2018 at 10:10 AM
HARRY P
  • 2,292 POSTS
As Roy suggested, definitely check the pump's output and the catalytic converter. The aftermarket pumps for these trucks are somewhat bad and often do not put out the pressure that they are supposed to. My aftermarket pump quit working, and the warranty replacement requires priming before I start it sometimes. You can borrow a fuel pressure tester from AutoZone and run the test for it. It should get something like 59 psi with the key turned on, engine off. As for the catalytic converter, the simplest way to check that is to take the upstream O2 sensors out and see how it does. It will be loud as heck though, so do not do it when the neighbors are asleep unless you really do not like them.
Jan 17, 2018 at 11:15 AM
HARRY P
  • 2,292 POSTS
Also, when you replaced the fuel pump, did you do the fuel filter as well? If not, it is definitely a good idea.
Jan 17, 2018 at 11:16 AM
MESABRINA
The catalytic converter was taken out when I got my muffler fixed. As for the fuel pump relay BTW was the problem I when to the auto parts store and got a new one starts right up thank you.
Jan 17, 2018 at 11:44 AM
