1994 Chevy Blazer Won't start
ISKITA4
  • 1994 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 118,000 MILES
Cranks over, wont start. Will start on ether, after you start it on ether it will start and run on its own. You can shut it off and it will start right back up on its own.
Sunday, January 24th, 2010 AT 12:45 PM
When you turn key to run -do you hear the fuel pump come On for 2secs? If not test the fuel pump relay, if so check fuel pressure if its within specs also the coolant temperature sensor
Sunday, January 24th, 2010 AT 1:25 PM
ISKITA4
We have already done and tried all of those things. Now it will not turn over at all. What are the odds of it being the distributor or the computer?
Wednesday, January 27th, 2010 AT 7:42 PM
Earlier it was starting with ether: Now it will not turn over at all
Have you checked for ignition spark? If you have spark I suggest you check the valve and ignition timing
Wednesday, January 27th, 2010 AT 8:13 PM
