Cranks but will not start
140,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
AUSTIN GRANGER
Originally started with it starting and running for a few seconds and shutting off. replace spark plugs, distributor cap, mass air flow sensor, and a few other things i forget what. but we finally replaced the computer and after it blowing a fuse and need of a jump start it ran. i drove it back to my house and it ran fine other than if i pushed in the clutch it would idle so low it would shut off. Wednesday morning 6:30 i wake up and start the truck to make sure it starts i shut it off after letting it idle for a bit. 7:15 go to start it it turns over until the battery dies. i put the battery charger to go and leave for school with my friend. after school get home and go out to start truck turns over but will not start. i replaced all the fuses and it burped when i turned it over but now just cranks.
Dec 19, 2018 at 9:52 AM
  • 55,746 POSTS
When the engine wont start can you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for five seconds? Here is a guide to help us get started:
Please run down this guide and report back. Cheers, Ken
Dec 20, 2018 at 10:59 AM
AUSTIN GRANGER
I did replace the fuel pump and fuel filter. The fuel pump does turn on but still no go.
Dec 25, 2018 at 2:17 PM
  • 55,746 POSTS
Can you spray starting fluid inside the intake and crank it, does it start? Did you check for spark?
Dec 27, 2018 at 8:56 AM
AUSTIN GRANGER
It will start when I spray starter fluid inside.
Mar 22, 2019 at 12:53 AM
  • 55,746 POSTS
Okay great, since you can hear the fuel pump running lets test the injector pulse by following this guide:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Mar 23, 2019 at 7:25 AM
