It is a 2500, gas engine. Cranks, but will not start.
Borrowed advanced scan tool (Autel). In live data section, can see state of ASD and fuel pump relays, they both turn on during crank. Can see injector PW during crank. Ran diagnostic on PCM/TCM, both passed. Checked codes, none. Removed ignition fuse, can hear a relay click when fuse put back in (ignition on). Fuel pump cycles when ignition turned on. Spark good off coil, but weak off spark plug wire.
Sprayed start fluid in intake, still no start. I am a Ford guy, working on truck for friend. Is there really a crank sensor near flex plate that you have to remove transmission to get to? Is there a way to test pickup coil in distributor (think Dodge calls it cam sensor? ). Thanks
Nov 30, 2018 at 9:28 AM
