2000 Isuzu NPR Crank No Start
100,000 MILES • 4.0L • TURBO • AUTOMATIC • DIESEL
EDWARD_1
  • 8 POSTS
Truck stalled when exiting highway, crank no start. I changed fuel filter & cleaned water seperator. Reprimed system multiple times still no start. I hit it with starter fluid and it fires right up. ??
Oct 31, 2026 at 4:31 PM
EDWARD_1
  • 8 POSTS
Fires up then dies right back out. Batteries are charged, reprimed again cracked injectors im getting spray, still no start??
Oct 31, 2026 at 5:24 PM
EDWARD_1
  • 8 POSTS
Its a 2000 izuzu Npr intercooled turbo diesel box truck.
Oct 31, 2026 at 5:25 PM
STEVE W.
  • 15,423 POSTS
When was the last time you filled it in terms of when this started and where? I would start by getting a sample of the fuel and testing it. Wouldn't be the first time for contaminated fuel. The NPR has also had issues where the rubber fuel lines get degraded and will collapse internally and stop fuel flow. Normally you can feel this if you squeeze the lines, the bad ones will be VERY soft. Also there have been issues with them drawing air into the lines. For that using a temporary piece of clear line between the filter and the tank to look for air bubbles. It would also tell you if the pick-up in the tank has an issue, they can fail. It's also possible the pressure regulator has a problem, for that you need a scan tool to look at the pressures in the system.
I had one as a roll back for a while. Dealt with bad lines and a bad pick up as well. On mine the top of the tube developed pin holes so it would suck in air and lose prime.
Oct 31, 2026 at 11:33 PM
EDWARD_1
  • 8 POSTS
So im broke down still from this on the side of the road in Jackson Nj. Ive checked all the fuses, ive primed it so many times its not funny. I pulled the banjo bolt with screen ( it didnt look clogged) but cleaned it with brake clean, even tried bypassing the tank completely with a diesel can and still cant get it to fire on its own. But since im desperate and already missed multiple says of work I sprayed it with starting fluid and it fired right off, then died. I had to verify cause this is driving me crazy. Any help will be appreciated. A further note my fuel gauge hasn't worked since I bought the truck and im almost positive I have just less than a half tank. I bring this up because I tried to add fuel from my can and it wont accept it. Filler neck fills uo and overflows. Could this be affecting my stalled now cranking no start issue??
Nov 1, 2026 at 1:04 PM
  • 55,845 POSTS
Okay, lets run the codes to see if any are stored, also did you check the fuses? Here are two videos to see what is going on.
https://www.youtube.com/watch?v=LBCpCWEFnTg
and to check the fuses.
https://www.youtube.com/watch?v=G-xNK79Wa-w&pp=0gcJCSsMAYcqIYzv
This can be a bad ECM.
Nov 2, 2026 at 7:19 AM
STEVE W.
  • 15,423 POSTS
Yeah, that's a fuel issue. Does your truck have the manual shut down or the electronic version? I would verify it didn't move to shut down. I had a cable fail on one and it wouldn't start. The only other item would be if the pump or rack has a problem. A test of the pump might be to hook up and external pump between the tank rack. If it starts and runs the pump failed. There are places that rebuild those.
Nov 2, 2026 at 7:36 AM
EDWARD_1
  • 8 POSTS
How and where can I hook up an external pump to test it? I have the main fuel tank bypassed already with a 5 gallon diesel can and a marine primer ball. Its still not starting. If you can send me a link to a video id really appreciate it.
Also I read something saying an " angle crank sensor"if it fails id get the same symptoms but I dont see it by the flywheel? Any ideas on that would help also
Nov 2, 2026 at 11:49 AM
EDWARD_1
  • 8 POSTS
And Yes I checked all the fuses with a multimeter even the 3 hidden ones in the dash. All were good. Any other ideas that will help me get this running? And since the batteries died from cranking I dont think im going to get any codes out of it.
Nov 2, 2026 at 3:59 PM
STEVE W.
  • 15,423 POSTS
I have put a pump in the line from a can into the feed line off the tank. Run the pump and you should get fuel out the return line. If it starts you have a pump problem.
Nov 2, 2026 at 5:21 PM
EDWARD_1
  • 8 POSTS
So how can I diagnose whats wrong with truck? I seriously need it back on the road for work Asap.
Nov 2, 2026 at 11:21 PM
STEVE W.
  • 15,423 POSTS
You have a fuel problem. The thing is that you need to narrow down where that problem is. You say it will start and run on spray, that means pretty much everything else is working so it is either a blocked fuel line, which if you prime it and get fuel at an injector or out the return line, is ruled out. So it has to be either the pump or the injector rack that isn't pushing the fuel through. If you put a pump on the fuel feed line from your spare fuel can and push fuel that way and it comes out the return line and then it starts and runs the pump on the engine is the problem, it just isn't pumping. If it still doesn't start then it is in the injection pump rack. Not a lot of other things it could be.
Nov 3, 2026 at 1:01 AM
EDWARD_1
  • 8 POSTS
Ok thank you for narrowing it down. Can you send me a link or video on how to remove the pump and or the rack so I can clean it or pull it out to diagnose?
Thank You
Nov 3, 2026 at 2:02 PM
  • 55,845 POSTS
Sorry, they don't give us the fuel pump information on this truck.
Nov 5, 2026 at 8:53 AM
STEVE W.
  • 15,423 POSTS
They don't usually have that information because the pump and injector rack require very specific tools to take them apart and set them up while they are off the engine. The common process is to order a reman unit and swap it if there is a problem. There will be an ID number on the pump that you go by to get the replacement.
Nov 5, 2026 at 12:06 PM
Suggested Repair
Treat this as a fuel-delivery problem. Check for contaminated fuel, collapsed soft fuel lines, air leaks, a failed tank pickup, and a stuck manual shutdown. Feed known-good fuel with an external pump into the feed line: if fuel exits the return and the engine runs, replace the injection pump with a reman unit matched to its ID number. If it still will not start, have the injector rack professionally diagnosed; do not disassemble the pump or rack without the required setup tools.
Conversation Summary
A 2000 Isuzu NPR turbo diesel stalled and then cranked but would not restart after the fuel filter was changed and the water separator cleaned. It briefly fired on starting fluid, and fuel spray was seen at cracked injectors, but it would not continue running. The owner also bypassed the tank with a diesel can, checked fuses, and noted a nonworking fuel gauge and a filler neck that overflowed. Experts identified a fuel-system fault and suggested checking contaminated fuel, collapsed lines, air leaks, the tank pickup, fuel pressure, and the shutdown control. Further testing with an external pump was recommended to distinguish a failed injection pump from an injector-rack problem; replacement with a matching reman unit was advised rather than DIY disassembly.
