Coolant temperature sensor or connector
  • 110,176 POSTS
Welcome back, Steve.
If you lose voltage when connected to the sensor, either the sensor is bad or you have a weak ground. Voltage really shouldn't change.
Saturday, July 27th, 2019 AT 5:58 PM
STEVEN SPELLMAN
  • 13 POSTS
I realized why the voltage was low. The voltage rises as the sensor heats up via the antifreeze. The question I have is I replaced my fuel pump before I tackled my timing belt. If the vehicle will start without the sensor plugged in would the fuel pump be the problem? It's a new fuel pump so I'm lost here.
Friday, August 23rd, 2019 AT 4:38 PM
  • 110,176 POSTS
Welcome back:
No sir, the pump wouldn't cause that to happen.
Friday, August 23rd, 2019 AT 8:38 PM
