Coolant leak and see blue liquid splash around engine, engine will not start?
2023 HONDA PILOT
200 MILES • 3.6L • V6 • 2WD • AUTOMATIC
MADHUVS
When trying to start it gives this this sound and engine doesn’t start.
Apr 2, 2023 at 2:25 AM
  • 110,244 POSTS
What sound does it produce when trying to restart it? Also, the blue liquid, is that the coolant you are referring to?
Is it possible for you to record the sound and upload it for me to hear? That may be helpful. As far as the coolant is concerned, by chance was the engine overheated prior to the issue. How much coolant has been lost?
Take a look through this link and let me know if you are able to locate the leak or at least the area it is leaking:
https://www.2carpros.com/articles/car-is-leaking-coolant
Apr 2, 2023 at 1:30 PM
