Coolant leak
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, it is possible that there could be a leak around the water pump area that is not only causing the leak but also dripping onto the belt causing the belt squealing noise. The first thing I suggest is to perform a cooling system pressure test. It is basically a pump that pressurizes the cooling system with the engine off. You can perform this with the engine off and cold to reduce injury. Once the system is pressurized you will be able to see where the leaks are coming from. If you don't have access to a pressure tester most auto parts stores have a tool loaner program and can rent you one. Here is tutorial showing how to pressure test:
https://www.2carpros.com/articles/radiator-pressure-test
Once you find the leak get back to us and we'll help with the repair. Hope this helps and thanks for using 2CarPros.
Thursday, December 24th, 2020 AT 8:35 AM (Merged)
RAQUON NASH
  • 2002 CHEVROLET MALIBU
  • V6
  • 4WD
  • 184,672 MILES
The car overheating the fans were not working. I replaced them and now it’s trying to start, but will not turn over and when I turn the key water coming from somewhere under the engine.
  • 52,797 POSTS
Good morning,
You need to perform a cooling system pressure test to determine the leak source.
It does not sound good. It may be the head gaskets that have failed from the overheating and is now preventing the car from starting.
