2003 Chevy Malibu Coolant Level keeps dropping
73,000 MILES • 6 CYL • FWD • AUTOMATIC
JENIBOB
Had leaks fixed in the water pump and cooling system by the dealership. Son took it on a trip (300 miles) and when he got back the Coolant light came on. Checked and there was hardly any coolant in it. Added coolant. Did fine and then he took it on a trip again (300 miles) and it did the same thing. Someone mentioned that the thermostat could be bad?
Dec 12, 2007 at 7:49 AM
  • 75,988 POSTS
If its the thermostat it will cause it to overheat. If there's no actual leakage I suspect that coolant is being burn in the combustion chamber due to a blown headgasket you might want the tests below done.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
Dec 12, 2007 at 8:06 AM
BLACKOP555
  • 10,386 POSTS
have your son check about 100 miles to see where the coolant is going, check for physical leaks, if none or noted then it is probably internal. post back.
Dec 12, 2007 at 8:07 AM
