Coolant pouring out the back of the engine
201,352 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
JANICE RENEE MYERS
I took car to Precision Tune to have water pump change. car came home with no coolant or oil in car, we put oil but when we put coolant in the radiator it pours out the back. is there a hose in the back that might be loose or not tighten?
Jan 7, 2019 at 1:04 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If you mean the water is pouring out the back near the firewall there are two heater hoses that feed the heater core inside the car. If the water is leaking near the back of the radiator one of those heater hoses feeds into the radiator. There are also two larger radiator hoses (upper and lower) that connect to the engine. I will look for more detailed pictures and get back to you. Hope this helps and thanks for using 2CarPros.
Danny-
Jan 7, 2019 at 3:12 AM
