The Climate Control Unit worked the day before and then the next morning the display had no power along with the external temperature display on the dashboard. Eventually the temperature started to work but it is not giving accurate temperature. All fuses and relays have been checked or switched but there was no changes. I replaced Climate Control and outside temperature sensor with working units from another 2004 Pilot but the results are the same. Can anyone help with this problem?
Jun 26, 2020 at 4:44 AM
