sluggish acceleration and rough shift change
2003 HONDA PILOT
95,000 MILES
MARINOFRANK
my 2003 honda pilot check engine light as been going on and off for the past couple of months ever since i changed the catalytic converter. Mechanic replaced the oxygen sensor
and said that if it comes back on, it might be a defective catalytic converter. for a few days now the check engine light blinks at times and the vtm-4 light comes on a few minutes later. the car has noticeably power but it doesn't sound like any of the cylinders are misfiring.
your help much appreciated. Thank you.
Aug 3, 2013 at 12:08 PM
  • 110,244 POSTS
If the converter is partially plugged, that will cause a power loss. Have that checked. Also, have the computer scanned to see if there are any trouble codes stored in it. Most parts stores will do it for free.
Aug 3, 2013 at 2:27 PM
