van not starting
SELENANICOLE2002
I have a 94 Chrysler town and country. It will not start. I was told it was the fuel pump. Could it be the fuel pump and if not what could it be?
Oct 27, 2007 at 1:29 PM
BMRFIXIT
  • 19,053 POSTS
[quote:89171ef948="SelenaNicole2002"]I have a 94 Chrysler town and country. It will not start. I was told it was the fuel pump. Could it be the fuel pump and if not what could it be?[/quote:89171ef948]
If some one told you it’s the fuel pump is it because they checked it
Or just ......
You need to check what is missing is it fuel
Spark or what else
You have the car we don’t we can help but we can not check from here what’s wrong with the van
So open the hood check what’s missing we can help just let us know
Good luck
Oct 27, 2007 at 2:57 PM
SELENANICOLE2002
The van was checked out by my husband as well as my father. The fuses were checked and it was checked to see if there was pressure and there is no fuel pressure. If not the fuel pump then what could it be?
Oct 28, 2007 at 6:47 AM
BMRFIXIT
  • 19,053 POSTS
[quote:575fedbe5e="SelenaNicole2002"]The van was checked out by my husband as well as my father. The fuses were checked and it was checked to see if there was pressure and there is no fuel pressure. If not the fuel pump then what could it be?[/quote:575fedbe5e]
most likely it the fuel pump
have your husband hit the fuel tank(in the mid) while u r trying to Start
if start u need a fuel pump
you can alSo check relay and wires
good luck
Oct 28, 2007 at 12:39 PM
GOAD
  • 5 POSTS
What would hitting the middle of the tank do? Force fuel thru by hitting it?
I just had the same thing happen to my 94 T/C. It wont start. I cant hear the pump pump when I first turn the key. So pretty sure the pump is gone.
Ken
Nov 14, 2007 at 5:05 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4f5ddd8c83="goad"]What would hitting the middle of the tank do? Force fuel thru by hitting it?
Ken[/quote:4f5ddd8c83]
CHECK THE RELAY
hitting the mid of fuel tank
it may or may not work
but if it does work it will get u to a shop
or home
on the same idea of hitting the starter the brushes will make contect and it will start
good luck
Nov 15, 2007 at 8:26 AM
  • 75,988 POSTS
If the ASD relay goes south you ain't gonna have spark, fuel pressure and fuel injector pulse.
Have a nice holiday
What BMR is trying to do hitting it might be a loose pump connector or the pump needs a wake up call BTDT. Also he mentioned Relays-lets check the ASD relay and go from there.
Nov 15, 2007 at 8:39 AM
