2003 Chrysler Town and Country No-Start Click Fix
MCCRAWD
My 2003 chrysler town and country 3.8 52k miles will not start it just clicks when you turn the ignition. We tracked it to a ground problem in the fuses box. Starter,cables, battery ect... checks fine. It just lost the ground! And ideas?
Apr 10, 2007 at 6:51 AM
  • 55,781 POSTS
I would start by checking the ground to the engine block and making sure the little ground wire from the battery is connected to the chassis or frame of the car, you must have both for the system to work correctly. Here are instructions of the negative battery cable so you can see what I am talking about.
REMOVAL
The battery cables on this model may include portions of wiring circuits for the generator and other components on the vehicle. If battery cable replacement is required, it will be necessary to extract the cables out of the engine wire harness assembly Use care not to damage the other wires and circuits which are also packaged into the engine wire harness assembly.
1. Turn the ignition switch to the OFF position. Be certain that all electrical accessories are turned Off.
2. Disconnect and isolate the negative battery cable terminal.
3. Remove the battery thermowrap (if equipped) from the battery tray
4. Remove the tape from the engine wire harness assembly, to access the desired battery cable.
5. One at a time, trace and disconnect the battery cable retaining fasteners and routing clips until the desired cable is free from the vehicle.
6. Feed the battery cable out of the vehicle.
INSTALLATION
1. Position the battery cable in the vehicle.
2. One at a time, trace and install the battery cable retaining fasteners and routing clips until the desired cable is properly installed in the engine wire harness assembly
3. Install the tape on the engine wire harness assembly
4. Install the battery thermowrap (if equipped) on the battery tray
5. Connect the negative battery cable terminal.
This guide can help as well:
Jul 12, 2022 at 9:58 AM
Suggested Repair
Verify the engine-block ground and the small battery ground wire to the chassis or frame; both must be connected. Inspect and correctly reinstall the negative battery cable, fasteners, and routing clips, then follow the related electrical no-start guide.
Conversation Summary
The owner of a 2003 Chrysler Town and Country 3.8 says it clicks and will not start. The starter, cables, and battery tested fine, and the owner traced a lost ground at the fuse box. The expert advises checking the engine-block ground and battery-to-chassis ground, and provides negative battery cable removal and installation steps plus a related guide.
