1996 Chrysler Town and Country Steering Shake Fix
EYESSOBLUE
[b:2dd1d65251]when driving the steering wheel shakes almost like a fast vibration, what could cause this? she sort of pulls to the right some what, alignment is needed, but what could cause the steering wheel vibrate like it does?[/b:2dd1d65251]
Jan 24, 2006 at 3:52 PM
SC1 RACING
  • 117 POSTS
an alignment should fix the vibration as well.
what is hapening is when the tires arent aligned it will drag/push the side out of alignment, and you will feel it in the steering wheel. if not fixed soon you will wear your tires, or if bad enough it could damage or cause wear to other suspension parts.
Jan 25, 2006 at 3:13 AM
EYESSOBLUE
Thank you so much for your input on my situation, I do have an alignment lined up for next week, thank you again...
Jan 25, 2006 at 3:48 PM
Suggested Repair
Have a wheel alignment performed. Misalignment can cause the steering wheel to vibrate and the vehicle to pull, and delaying the repair can wear the tires and other suspension parts.
Conversation Summary
The owner of a 1996 Chrysler Town and Country LXI 3.8L reported a fast steering-wheel vibration while driving and a slight pull to the right, and noted that an alignment was needed. The expert said an alignment should also correct the vibration because misaligned tires drag and transmit that feel through the steering wheel, and warned that delaying it can wear the tires or suspension parts. The owner thanked the expert and said an alignment was already scheduled.
