2001 Chrysler Town & Country A/C Compressor Fix
JKROBBINS
It's the hottest week of the season and of course my A/C quit entirely on my 2001 Chrysler Town & Country LTD (84k).
The mechanic diagnosed the problem as needing a new compressor. Is this a Do It Yourself project that I could do? I don't have $1100 to replace the compressor and flush/recharge the system so if it's possible for me to do all or most of this project myself it would be great.
Are there things I should be particularly concerned with or careful about? Is there a place where I might find good step-by-step guidance? What other associated parts should be replaced at the same time (filters/hoses/whatever)?
Thanks!
Jul 24, 2006 at 9:13 AM
MIKEYBDMAN
  • 623 POSTS
This is a do it yourself project if you are willing to get a little dirty.
You should be able to order a new compressor, and I would suggest getting one with a new clutch and pully installed. They cost a little more, but if you get just the compressor, you will have to swap over the clutch and pulley. This can be done, but it is more work and you will have an old clutch and pulley on your new compressor.
You will also need to replace the accumulator/reciever dryer and the orifice tube at the same time as you replace the compressor.
After you have the system disassembled, you will need to put A/C flush fluid in the evaporator and condensor and flush all of the lines. This is very important if your compressor has gone bad, it will have contaminated the sytem with particals that will destroy the new compressor, or clog the new orifice tube.
If your system still has freon in it, then it is a good idea to find an air conditioning mechanic that will extract the freon and give you credit on reservicing the system when you are done.
Just guessing on parts and the cost of have it reserviced, I would say you are looking at around $500-$600 to do it yourself. But check the price of all parts first.
Jul 24, 2006 at 9:52 AM
Suggested Repair
A compressor replacement can be DIY if you are willing to get dirty. Install a compressor that already includes a new clutch and pulley, and also replace the accumulator/receiver dryer and orifice tube. Flush the evaporator, condenser, and lines to remove debris, have any remaining refrigerant professionally recovered, then have the system recharged. Parts plus recharge were estimated at about $500-$600.
Conversation Summary
The owner of a 2001 Chrysler Town & Country with 84,000 miles said the A/C quit completely and a mechanic recommended a compressor replacement costing about $1,100. They asked whether the job was DIY, what precautions to take, where to find steps, and which related parts to replace. The expert said it is DIY, recommended a compressor with a new clutch and pulley, plus a new accumulator/receiver dryer and orifice tube, and stressed flushing the evaporator, condenser, and lines so debris does not damage the new parts. They also advised professional refrigerant recovery and recharge, estimating about $500-$600.
