2001 Chrysler Town and Country Air conditioning compressor?
145,000 MILES • 6 CYL • FWD • AUTOMATIC
THAYERT
I have taken this vehicle to the dealer they said the PCM was the cause for the compressor not receiving the rely to engage the ac. I replaced the PCM and the ac compressor clutch relay in the pdc box I still have the same problem no cold air I've tried adding R-134A to the system but that has not helped. Where do I go from here?
Jul 13, 2010 at 10:23 AM
  • 75,988 POSTS
Do you hear the clutch engage the compressor when you turn AC On if not could be a freon problem if not power the clutch from the battery and see if it engages the compressor
Jul 13, 2010 at 11:22 AM
THAYERT
I don't hear the clutch engage only the blower begans pushing warm air into the cabin. I have tried "recharging" my R-134a when I attach the canister to the ac line it reads overcharged or the can label also states it could me a mechanical issue. Also If i hook up the compressor to the battery and it doesn't engage is it safe to say that I have a bad compressor? And where can I find a "how to" on hooking up the compressor to the battery. Thanks agian.
Jul 13, 2010 at 2:42 PM
