2003 Chrysler Town and Country lights
2003 CHRYSLER TOWN AND COUNTRY
101,000 MILES • 6 CYL • FWD • AUTOMATIC
CHUCK101
MY head lights,tail lights and instrument lights suddenly went out while driving. The interior dome light came on, could get head lights to work by pulling in on dimmer lever, pulled off the road and sat there for about 15 minutes switching the vehicle off once, started back up and still no lights, then after a couple of minutes everthing started working again. Any ideas what to check? Thank you
Oct 4, 2009 at 4:35 AM
JDL
  • 16,098 POSTS
Welcome to the forum. You could have the codes checked, see if it points to anything, manufacturer specific codes. I'd have to track the circuit when the problem occurs. The headlamp switch sends a signal to the bcm, the bcm sends a signal to the front control module. The lamp drivers are in the front control module. I can't say the module is faulty, the problem could be almost anywhere.
Oct 4, 2009 at 5:52 AM
