To the best of my knowledge, you need to remove the cluster to access them. Once out, you will see a printed circuit board on the rear. Identify where the light is that is bad to replace it. Also, if I remember correctly, you actually have to take the cluster apart to get to the bulb.
Mar 15, 2010 at 6:21 AM
