Hello, if there is no primary voltage to the coil pack or injectors, engine cranking, that will lead back to the asd relay. Check the voltage feed to the asd relay, that is controlled by a fuse 16, 25 amp, that circuit is hot all the time. If the computer isn't grounding the asd relay--coil pack-- injectors, that is another issue. Usually because it doesn't see the proper cam and crank signals?
You may need to turn the key on, see if there is any reference voltage to sensors that use a ref voltage.
SPONSORED LINKS
Sunday, August 30th, 2020 AT 12:03 PM
