I have a 1997 t&c that I just replaced the condensor in and recharged the ac. After about two weeks of driving I start have a problem. First the engine would shutter after I slowed down at a stop light but not cut off. Then after a few days the engine stared cutting off at stops. And now after I start the engine and shift to drive or reverse the engine shuts down right away. I noticed that If I shift into drive and give it gas right away that I runs normal but as soon as I come to a stop it cuts off. The check engine light does not even come on. What could be the cause of this problem? Is it a transmission problem, engine, computer or what?
May 19, 2009 at 2:16 AM
