1999 Chrysler Sebring Jerk and Surge
P0106?
Lean condition. The first thing to check for is a vacuum leak. Check all hoses and connections, especially the brake booster and PCV valve. Also check the intake manifold especially around cylinder 6.
The O2 could be due for a change. Most manufacturers recomend change @ 100,000 miles.
Cylider 6 misfire could also be a vacuum leak or O2.
Check the MAP sensor for proper electrical onnection. Make sure the vacuum lines are not clogged and connected with good vacuum.
Good hunting and let us know. :)
Suggested Repair
Check for vacuum leaks at hoses and connections, especially the brake booster, PCV valve, and intake manifold around cylinder 6. Verify the MAP sensor electrical connection and that its vacuum lines are clear and have good vacuum. Consider replacing the oxygen sensor, often due around 100,000 miles. These checks address the lean condition and cylinder 6 misfire before assuming faulty fuel injectors.
Conversation Summary
The owner of a 1999 Chrysler Sebring V6 coupe with about 112,000 miles reports jerking when accelerating from a stop or after slowing, followed by a sudden surge. A fuel pump, filter, and tune-up were recently completed, and codes showed a rear bank lean condition and a cylinder 6 misfire. The expert recommends checking for vacuum leaks, including the brake booster, PCV valve, and intake near cylinder 6, inspecting the MAP sensor and its vacuum lines, and considering an oxygen sensor replacement due around 100,000 miles.
