2001 Chrysler Sebring Blinkers not working
DRAGONIST
Electrical problem
2001 Chrysler Sebring 4 cyl Front Wheel Drive Automatic 13000+ miles
Blinkers stop working,checked the dash where the alarm is located. I seen a wire that was'nt connected. In the process of connecting the wire the blinkers started to work, connected the wire and they will no longer work. When arming and disarming the alarm system the blinkers do blink. Also the driver side swith to lock and unlock the doors will not work. How can i correct these issues.
May 8, 2009 at 4:33 PM
RACEFAN966
  • 5,029 POSTS
Ok first I need to know if you have a digital multi meter so we can do some testing and checking for power? Get back to me and I will look over the wiring diagram and go from there.
May 9, 2009 at 1:53 AM
