1999 Chrysler Sebring
DAVIDK6699
  • 1999 CHRYSLER SEBRING
Steering problem
1999 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
the steering column seems to be squeaking when you turn the wheel but up on jacks it doesn't make any noise and seems to work fine, any suggestions?
Tuesday, March 9th, 2010 AT 1:11 PM
CARADIODOC
  • 33,916 POSTS
Use a hooked tool to pull back the rubber seal under the dash where the steering shaft goes through the firewall. Spray a lubricant inside the seal. Chrysler's "White Spray Lube" works very nicely.
Caradiodoc
Thursday, March 11th, 2010 AT 3:39 PM
